Introduction
The base's motherboard is attached via wires, to the bracket of the charging contact points.
  1. Unscrew the two 10.0mm Philips #0 screws located on the bottom and the back of the base. There should be two screws on the bottom of the base and a single screw on the back. Unscrew the two 10.0mm Philips #0 screws located on the bottom and the back of the base. There should be two screws on the bottom of the base and a single screw on the back.
    • Unscrew the two 10.0mm Philips #0 screws located on the bottom and the back of the base. There should be two screws on the bottom of the base and a single screw on the back.
  2. Facing the bottom side of the base, run the black spudger along the crevice to one side, and then to the other. With a gentle application of force, the two parts of the base's body should separate.
    • Facing the bottom side of the base, run the black spudger along the crevice to one side, and then to the other.
    • With a gentle application of force, the two parts of the base's body should separate.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  4. Hold the anterior part of the base's body, with the side which shows only the exterior, facing the palm.
    • Hold the anterior part of the base's body, with the side which shows only the exterior, facing the palm.
    • Unscrew the 10.0mm Philips #0 round head screw, located on the black bracket which holds the charger contact points.
    • The black bracket should pop off.
  5. Gently pull up on motherboard, in order to separate it from the base.
    • Gently pull up on motherboard, in order to separate it from the base.
Sheckeem Daley
573 Reputation
5 Guides authored
USF Tampa, Team 16-4, Blackwell Winter 2016 Member of USF Tampa, Team 16-4, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 413
