Uniden D1483-3BK Handset Case Separation
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Uniden D1483-3BK Handset Case Separation, Handset Case: step 1, image 1 of 2 Uniden D1483-3BK Handset Case Separation, Handset Case: step 1, image 2 of 2
    • Remove the two 9mm Phillips #1 screws in the battery compartment.
  2. Uniden D1483-3BK Handset Case Separation: step 2, image 1 of 3 Uniden D1483-3BK Handset Case Separation: step 2, image 2 of 3 Uniden D1483-3BK Handset Case Separation: step 2, image 3 of 3
    • Use the plastic opening tool to carefully separate the two halves of the case.
    • Slowly work around the entire case to fully separate the halves before pulling them apart.
    • Wires inside the case hold the two halves together, tearing these wires will lead to a need for additional repair.
  3. Uniden D1483-3BK Handset Case Separation: step 3, image 1 of 2 Uniden D1483-3BK Handset Case Separation: step 3, image 2 of 2
    • Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
  4. Uniden D1483-3BK Handset Case Separation: step 4, image 1 of 2 Uniden D1483-3BK Handset Case Separation: step 4, image 2 of 2
    • Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
    • Set the board in the lower half of the case.
5 other people completed this guide.
Arbitrary Name
1,083 Reputation
4 Guides authored
Penn State, Team 1-8, Kaschak Winter 2015 Member of Penn State, Team 1-8, Kaschak Winter 2015
PSU-KASCHAK-W15S1G8
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 55
