USB-Kabel Knikbeveiliging repareren
  1. USB-Kabel Knikbeveiliging repareren, USB-Kabel Knikbeveiliging repareren: step 1, image 1 of 1
    • Outer insulation is damaged but the cable is working.
  2. USB-Kabel Knikbeveiliging repareren: step 2, image 1 of 1
    • Spring from an old ballpoint pen, approx. 30mm long.
  3. USB-Kabel Knikbeveiliging repareren: step 3, image 1 of 1
    • Turn the spring around the cable.
  4. USB-Kabel Knikbeveiliging repareren: step 4, image 1 of 1
    • Then continue to "wrap".
  5. USB-Kabel Knikbeveiliging repareren: step 5, image 1 of 1
    • The spring must be pulled slightly over the old bend protection.
  6. USB-Kabel Knikbeveiliging repareren: step 6, image 1 of 1
    • Finally fix with super glue and also glue the damaged area.
Volg de stappen in omgekeerde volgorde om je apparaat weer in elkaar te zetten.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
John Raster
200 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 23
All Time: 1,539
