Introduction
Required is:
  • one spring from a ballpoint pen
  • Superglue
The spring is pushed over the damaged area so that the spring surpasses the damaged area slightly on both sides. Then glue with super glue on the plug side.
  1. Outer insulation is damaged but the cable is working.
    • Outer insulation is damaged but the cable is working.
  2. Spring from an old ballpoint pen, approx. 30mm long.
    • Spring from an old ballpoint pen, approx. 30mm long.
    • Turn the spring around the cable.
    • Then continue to "wrap".
    • The spring must be pulled slightly over the old bend protection.
    • Finally fix with super glue and also glue the damaged area.
Follow the steps in the reverse order to reassemble your device.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
John Raster
119 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 22
All Time: 239
