Remove the ear pad from the earphone by gently pulling the cloth pad outwards from the slot holding the cloth.
Work circularly until removed.
Using a Phillips #1 screwdriver, remove the four fastening screws that hold the blue plastic speaker mount in place.
Gently pull blue plastic from black housing by hand until separated.
Circuit board will be free to be removed by hand. Use plastic pry tool to slide between casing and circuit board if needed.
Gently removed and flip over circuit board to reveal battery pack attached to the underside. Careful not to pull out wires running through headband.
Use metal pry tool to slide between battery and circuit board to break up adhesive. Ensure the battery wire connector plug has been removed on front side.
