Trio Stealth G2 Hype Speakers Replacement
  1. Trio Stealth G2 Hype Speakers Replacement, Back Panel: step 1, image 1 of 2 Trio Stealth G2 Hype Speakers Replacement, Back Panel: step 1, image 2 of 2
    • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
  2. Trio Stealth G2 Hype Speakers Replacement: step 2, image 1 of 1
    • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
  3. Trio Stealth G2 Hype Speakers Replacement: step 3, image 1 of 3 Trio Stealth G2 Hype Speakers Replacement: step 3, image 2 of 3 Trio Stealth G2 Hype Speakers Replacement: step 3, image 3 of 3
    • Remove the speakers by using your hand to entirely disconnect the back cover.
  4. Trio Stealth G2 Hype Speakers Replacement, Speakers: step 4, image 1 of 2 Trio Stealth G2 Hype Speakers Replacement, Speakers: step 4, image 2 of 2
    • Carefully peel the tape holding down the wires connected to the speaker.
  5. Trio Stealth G2 Hype Speakers Replacement: step 5, image 1 of 1
    • In order to replace the speakers after they are removed, you must solder the wires back onto the motherboard.
    • The red wire must be soldered onto the "+" terminal while the black wire must be terminal must be soldered onto the "-" terminal.
    • Pull the speaker and wires from the motherboard.
Thomas Lichtenberger
459 Reputation
3 Guides authored
USF Tampa, Team 4-4, Brown Winter 2015 Member of USF Tampa, Team 4-4, Brown Winter 2015
USFT-BROWN-W15S4G4
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 220
