Trek 800 Mountain Track 1994 Front Brakes Replacement
  1. Trek 800 Mountain Track 1994 Front Brakes Replacement, Front Brakes: step 1, image 1 of 1
    • Check if your brake pads are worn down. If they are less than ¼ of an inch thick, it is time to replace them.
  2. Trek 800 Mountain Track 1994 Front Brakes Replacement: step 2, image 1 of 3 Trek 800 Mountain Track 1994 Front Brakes Replacement: step 2, image 2 of 3 Trek 800 Mountain Track 1994 Front Brakes Replacement: step 2, image 3 of 3
    • First, unscrew the pinch bolt on the left front brake using an adjustable wrench.
  3. Trek 800 Mountain Track 1994 Front Brakes Replacement: step 3, image 1 of 3 Trek 800 Mountain Track 1994 Front Brakes Replacement: step 3, image 2 of 3 Trek 800 Mountain Track 1994 Front Brakes Replacement: step 3, image 3 of 3
    • Unhook the brake cables from both sides.
  4. Trek 800 Mountain Track 1994 Front Brakes Replacement: step 4, image 1 of 2 Trek 800 Mountain Track 1994 Front Brakes Replacement: step 4, image 2 of 2
    • Starting with the right brake pad, unscrew the bolt seen in the left side of the brake caliper using an adjustable wrench.
  5. Trek 800 Mountain Track 1994 Front Brakes Replacement: step 5, image 1 of 3 Trek 800 Mountain Track 1994 Front Brakes Replacement: step 5, image 2 of 3 Trek 800 Mountain Track 1994 Front Brakes Replacement: step 5, image 3 of 3
    • Take out the brake pad and the bolt that held it in.
    • Make sure to save this bolt assembly.
  6. Trek 800 Mountain Track 1994 Front Brakes Replacement: step 6, image 1 of 3 Trek 800 Mountain Track 1994 Front Brakes Replacement: step 6, image 2 of 3 Trek 800 Mountain Track 1994 Front Brakes Replacement: step 6, image 3 of 3
    • Make sure the new brake pad says "R front".
    • Unscrew the bottom nut of the new brake pad using an Allen wrench.
    • Slide the bolt assembly that was saved onto the new brake pad.
    • Screw the nut back on using an Allen wrench.
  7. Trek 800 Mountain Track 1994 Front Brakes Replacement: step 7, image 1 of 3 Trek 800 Mountain Track 1994 Front Brakes Replacement: step 7, image 2 of 3 Trek 800 Mountain Track 1994 Front Brakes Replacement: step 7, image 3 of 3
    • Put the new brake pad back into the holder located near the wheel and screw the bolt on the left side using an adjustable wrench.
    • Also, tighten the bottom nut of the new brake pad using an Allen wrench.
  8. Trek 800 Mountain Track 1994 Front Brakes Replacement: step 8, image 1 of 1
    • Make sure the brake pad is parallel to the tire. This will ensure that the brake pad hits the wheel correctly.
  9. Trek 800 Mountain Track 1994 Front Brakes Replacement: step 9, image 1 of 1
    • Hook the brake cable back in on the right side.
  10. Trek 800 Mountain Track 1994 Front Brakes Replacement: step 10, image 1 of 3 Trek 800 Mountain Track 1994 Front Brakes Replacement: step 10, image 2 of 3 Trek 800 Mountain Track 1994 Front Brakes Replacement: step 10, image 3 of 3
    • Repeat steps 4-9 on the left side: unscrew the bolt to take out the old brake pad, put the new brake pad back on to the holder near the bike wheel, and screw everything back into place.
    • Use an adjustable wrench and Allen wrench as described before.
  11. Trek 800 Mountain Track 1994 Front Brakes Replacement: step 11, image 1 of 1
    • Hook the brake cable back in on the left side.
  12. Trek 800 Mountain Track 1994 Front Brakes Replacement: step 12, image 1 of 2 Trek 800 Mountain Track 1994 Front Brakes Replacement: step 12, image 2 of 2
    • Screw the pinch bolt back onto the brake system using an adjustable wrench.
  13. Trek 800 Mountain Track 1994 Front Brakes Replacement: step 13, image 1 of 1
    • Sandpaper your brakes to maintain symmetry on either side of the wheel.
  14. Trek 800 Mountain Track 1994 Front Brakes Replacement: step 14, image 1 of 1
    • Lubricate the brake cables using brake oil to make sure the brake system runs smoothly.
  15. Trek 800 Mountain Track 1994 Front Brakes Replacement: step 15, image 1 of 1
    • Do a test run for the new brake pads and make sure they apply friction as they are supposed to.
Finish Line
Annemarie
241 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 20
All Time: 381
