Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement
  1. Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement, Battery Replacement: step 1, image 1 of 3 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement, Battery Replacement: step 1, image 2 of 3 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement, Battery Replacement: step 1, image 3 of 3
    • Unplug your laptop from any source of power.
    • Lay your laptop on a soft, clean surface as shown.
    • Using the metal spudger, remove the two rubber grips on the bottom face of the laptop, located closest to the hinge.
    • The grips may be brittle. Be careful when removing them with the metal spudger so as not to damage them.
  2. Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 2, image 1 of 3 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 2, image 2 of 3 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 2, image 3 of 3
    • Remove the ten 5mm Phillips #0 screws that secure the back plate to the computer.
  3. Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 3, image 1 of 3 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 3, image 2 of 3 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 3, image 3 of 3
    • Starting on the edge that is opposite the hinge, use the plastic opening tools to pry the back plate away from the computer.
    • Loosen the three non-hinge edges.
    • Leave a plastic opening tool in each corner to ensure that one side does not snap closed before you are done opening the others.
    • DO NOT lift the back plate away from the computer; it is still connected to the motherboard.
  4. Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 4, image 1 of 3 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 4, image 2 of 3 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 4, image 3 of 3
    • To loosen the back plate, lift it slightly and gently pull it away from the hinge.
    • Flip the back plate open towards the power button, but be sure to not pull on the ribbon cable that connects the back plate to the motherboard.
    • Use a plastic opening tool to detach the side of the ribbon cable connected to the computer by prying up gently on the small black lever at the point of attachment.
  5. Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 5, image 1 of 3 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 5, image 2 of 3 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 5, image 3 of 3
    • Remove the four 3mm Phillips #0 screws connecting the battery to the computer.
  6. Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 6, image 1 of 3 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 6, image 2 of 3 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 6, image 3 of 3
    • Use a plastic opening tool to lift the side of the battery that is closest to the long edge of the computer.
    • As you are pulling the battery away from the computer, unplug it from the side closest to the short edge of the computer.
    • There may be a lot of resistance when unplugging the battery. If there is, try to wiggle the male side of the plug back and forth as you remove it.
  7. Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement, Wireless Card (Wifi): step 7, image 1 of 2 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement, Wireless Card (Wifi): step 7, image 2 of 2
    • Remove the tape partially covering the wireless card. It may be helpful to do this using a plastic opening tool.
  8. Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 8, image 1 of 2 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 8, image 2 of 2
    • Loosen the 3mm Phillips #0 screw attaching the wireless card to the computer until there is enough room for the wireless card to be lifted past the height of the screw.
    • One or both of the antenna cables attached to the wireless card during may pop off during this step. This is ok.
  9. Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 9, image 1 of 3 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 9, image 2 of 3 Toshiba Satellite Radius P55W-B5112 Wireless Card (Wifi) Replacement: step 9, image 3 of 3
    • Remove the wireless card from the computer by gently pulling it in the direction of the further long edge of the computer, at an upwards angle.
    • If either of the antenna cables are still attached to the card, gently pull them off with your hands to free them.
Mudassar Abbas Khan
624 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 10
All Time: 923
