Introduction
In this guide you will be replacing the Wi-Fi adapter in your laptop. You'll need to use a Phillips #1 screwdriver to complete this repair.
Using a Phillips #1 screwdriver, remove the screw from the back cover.
Remove the back cover from the device.
Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop.
Remove the back cover from your device.
Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard.
Remove the Wi-Fi adapter from the device.
