Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement
  1. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Back Casing: step 1, image 1 of 2 Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Back Casing: step 1, image 2 of 2
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: step 2, image 1 of 2 Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: step 2, image 2 of 2
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: step 3, image 1 of 3 Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: step 3, image 2 of 3 Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: step 3, image 3 of 3
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Battery: step 4, image 1 of 2 Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Battery: step 4, image 2 of 2
    • Use the #PH0 screw head, remove 4 (5.7mm) screws.
    • Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
  5. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: step 5, image 1 of 1
    • Gently remove battery from the laptop.
  6. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement, Fan & CPU Cooler: step 6, image 1 of 1
    • Using a PH0 screwdriver, remove 2 (5.7mm) screws.
    • Using a PH0 screwdriver, remove 4 (3.68mm) screws.
  7. Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: step 7, image 1 of 2 Toshiba Satellite P55t-A5116 Fan & CPU Cooler Replacement: step 7, image 2 of 2
    • Unplug the 3 pin connector
    • Remove fan.
3 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,699
