Toshiba Satellite L755D-S5150 Keyboard Replacement
  1. Toshiba Satellite L755D-S5150 Keyboard Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite L755D-S5150 Keyboard Replacement, Battery: step 1, image 2 of 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Keyboard Replacement, Keyboard: step 2, image 1 of 1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Keyboard Replacement: step 3, image 1 of 1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Keyboard Replacement: step 4, image 1 of 1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
Shaheedah
276 Reputation
2 Guides authored
USF Tampa, Team 2-5, Sullivan Fall 2016 Member of USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 Members
5 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 855
