Toshiba Satellite L670 HDD replacement
  1. Toshiba Satellite L670 HDD replacement, Turn off the computer: step 1, image 1 of 1
    • Turn off the computer and unplug the power from the computer.
  2. Toshiba Satellite L670 HDD replacement, Flip Laptop: step 2, image 1 of 1
    • Turn the laptop upside down. Locate the two latches on either side of the battery.
    • Now the battery comes off.
  3. Toshiba Satellite L670 HDD replacement, Remove battery: step 3, image 1 of 2 Toshiba Satellite L670 HDD replacement, Remove battery: step 3, image 2 of 2
    • Remove the battery
  4. Toshiba Satellite L670 HDD replacement, Remove rear panel: step 4, image 1 of 2 Toshiba Satellite L670 HDD replacement, Remove rear panel: step 4, image 2 of 2
    • Remove the back plate
  5. Toshiba Satellite L670 HDD replacement, Remove the HDD: step 5, image 1 of 2 Toshiba Satellite L670 HDD replacement, Remove the HDD: step 5, image 2 of 2
    • Pull the HDD to the left using the silver tab.
    • Pull up on the silver tab and remove the hard drive from the slot.
  6. Toshiba Satellite L670 HDD replacement, Unscrew the HDD cover: step 6, image 1 of 2 Toshiba Satellite L670 HDD replacement, Unscrew the HDD cover: step 6, image 2 of 2
    • Remove the 4 screws from the hard drive.
  7. Toshiba Satellite L670 HDD replacement, Insert your new SSD in the case: step 7, image 1 of 3 Toshiba Satellite L670 HDD replacement, Insert your new SSD in the case: step 7, image 2 of 3 Toshiba Satellite L670 HDD replacement, Insert your new SSD in the case: step 7, image 3 of 3
    • Take your new SSD hard drive.
    • Place the SSD in the silver case.
    • Place back the 4 screws you just removed.
  8. Toshiba Satellite L670 HDD replacement, Insert SSD: step 8, image 1 of 2 Toshiba Satellite L670 HDD replacement, Insert SSD: step 8, image 2 of 2
    • Insert the SSD into the laptop.
    • Slide the SSD to the right into the socket.
  9. Toshiba Satellite L670 HDD replacement, Place back panel + battery: step 9, image 1 of 1
    • Replace the back panel and screw it in place.
    • Put the battery back in, you will hear a click once it falls into place.
To reassemble the device, follow these instructions in reverse order.
Special thanks to these translators:
nl en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
levi lenaers
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 38
All Time: 1,101
