Toshiba Satellite L305-S5875 Hinge Replacement
  1. Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: step 1, image 1 of 3 Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: step 1, image 2 of 3 Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: step 1, image 3 of 3
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  2. Toshiba Satellite L305-S5875 Hinge Replacement: step 2, image 1 of 1
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  3. Toshiba Satellite L305-S5875 Hinge Replacement: step 3, image 1 of 2 Toshiba Satellite L305-S5875 Hinge Replacement: step 3, image 2 of 2
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  4. Toshiba Satellite L305-S5875 Hinge Replacement: step 4, image 1 of 2 Toshiba Satellite L305-S5875 Hinge Replacement: step 4, image 2 of 2
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  5. Toshiba Satellite L305-S5875 Hinge Replacement: step 5, image 1 of 1
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
  6. Toshiba Satellite L305-S5875 Hinge Replacement, Hinge: step 6, image 1 of 2 Toshiba Satellite L305-S5875 Hinge Replacement, Hinge: step 6, image 2 of 2
    • Close your laptop and flip it over.
    • Remove the 13 screws using a Phillips #00 screwdriver.
  7. Toshiba Satellite L305-S5875 Hinge Replacement: step 7, image 1 of 1
    • Gently disconnect the ribbon cable.
    • Gently disconnect the multicolored cable.
  8. Toshiba Satellite L305-S5875 Hinge Replacement: step 8, image 1 of 1
    • Gently pull the top case from the bottom case of the laptop.
  9. Toshiba Satellite L305-S5875 Hinge Replacement: step 9, image 1 of 2 Toshiba Satellite L305-S5875 Hinge Replacement: step 9, image 2 of 2
    • Unscrew the two screws on the hinge. (Be careful to not damage nearby wires)
    • Both hinges shown, but replacing both may not be necessary.
    • Congratulations, you may now remove and replace your hinge!
Tyler
208 Reputation
2 Guides authored
One Comment
Will this work for a Toshiba satellite l655 model
ethanhunemuller - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 6,409
