Toshiba Satellite E45t-A4300 Fan Replacement
  1. Toshiba Satellite E45t-A4300 Fan Replacement, Back Panel: step 1, image 1 of 1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45t-A4300 Fan Replacement: step 2, image 1 of 1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45t-A4300 Fan Replacement, Fan: step 3, image 1 of 2 Toshiba Satellite E45t-A4300 Fan Replacement, Fan: step 3, image 2 of 2
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
  4. Toshiba Satellite E45t-A4300 Fan Replacement: step 4, image 1 of 1
    • Gently disconnect the fan cable from the device.
  5. Toshiba Satellite E45t-A4300 Fan Replacement: step 5, image 1 of 2 Toshiba Satellite E45t-A4300 Fan Replacement: step 5, image 2 of 2
    • Move the wires away from the fan’s hook.
    • Remove the fan from the device.
Jose Marques
433 Reputation
2 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 553
