Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
The solid state drive, or SSD in short, has the same functionality of the hard drive in storing data, but without a magnet. If the SSD is damaged from long time use or being given the wrong data, then a replacement for the SSD may be necessary.
Parts
No parts specified.
  1. Remove the twelve 5 mm  Phillips #1   screws from the back panel.
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Pry the back panel open with the plastic spudger or fingernails.
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  4. Remove the single 3 mm black screw using a Phillips #1 screwdriver. Remove the single 3 mm black screw using a Phillips #1 screwdriver.
    • Remove the single 3 mm black screw using a Phillips #1 screwdriver.
  5. Pull the SSD away from the motherboard.
    • Pull the SSD away from the motherboard.
James Nguyen
552 Reputation
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 201
