Toshiba Satellite C660 HDD / RAM Memory Replacement
Video Overview
  1. Toshiba Satellite C660 HDD / RAM Memory Replacement, HDD / RAM Memory: step 1, image 1 of 3 Toshiba Satellite C660 HDD / RAM Memory Replacement, HDD / RAM Memory: step 1, image 2 of 3 Toshiba Satellite C660 HDD / RAM Memory Replacement, HDD / RAM Memory: step 1, image 3 of 3
    • Remove the battery.
    • Unscrew 1x Phillips screw and disassemble the HDD / RAM memory cover.
  2. Toshiba Satellite C660 HDD / RAM Memory Replacement: step 2, image 1 of 3 Toshiba Satellite C660 HDD / RAM Memory Replacement: step 2, image 2 of 3 Toshiba Satellite C660 HDD / RAM Memory Replacement: step 2, image 3 of 3
    • Use a plastic tool and an anti static gloves to pull out the memory modules.
    • If you have not, then hold the board only at the ends.
    • If you plan to make an upgrade, first of all check the specification of yours model. Depending of the Chipset and the producer, every laptop have a limit of the expansion of the RAM memory.
    • Check exactly type of the used memory modules. This models use DDR3 technology.
    • You can use modules with a different speed but the processor will work with them at the speed of the slower one.
    • Some modules will not work together.
  3. Toshiba Satellite C660 HDD / RAM Memory Replacement: step 3, image 1 of 3 Toshiba Satellite C660 HDD / RAM Memory Replacement: step 3, image 2 of 3 Toshiba Satellite C660 HDD / RAM Memory Replacement: step 3, image 3 of 3
    • Now let's remove the HDD.
    • Remove the hard drive by sliding it away from the port towards the screw hole.
  4. Toshiba Satellite C660 HDD / RAM Memory Replacement: step 5, image 1 of 2 Toshiba Satellite C660 HDD / RAM Memory Replacement: step 5, image 2 of 2
    • Unscrew the 4x Phillips screws and separate the HDD from the HDD caddy.
    • You can upgrade your HDD to maximum 1TB.
ZFix
191,278 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,528 Guides authored
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 84
All Time: 11,850
