Toshiba Satellite A75-S226 Wi-Fi/Memory Cover Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Toshiba Satellite A75-S226 Wi-Fi/Memory Cover Replacement, Wi-Fi/Memory Cover: step 1, image 1 of 2 Toshiba Satellite A75-S226 Wi-Fi/Memory Cover Replacement, Wi-Fi/Memory Cover: step 1, image 2 of 2
    • Remove the 5.75 mm screw from the cover panel.
    • Turn the laptop over with the screen facing down.
  2. Toshiba Satellite A75-S226 Wi-Fi/Memory Cover Replacement: step 2, image 1 of 1
    • Lift up the cover panel using a plastic opening tool.
Garrett Gudgel
763 Reputation
13 Guides authored
Cal Poly, Team 4-43, Amido Fall 2010 Member of Cal Poly, Team 4-43, Amido Fall 2010
CPSU-AMIDO-F10S4G43
5 Members
39 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,273
