Toshiba Satellite A210 Optical Disc Drive Replacement
  1. Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: step 1, image 2 of 2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Optical Disc Drive Replacement: step 2, image 1 of 2 Toshiba Satellite A210 Optical Disc Drive Replacement: step 2, image 2 of 2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: step 3, image 1 of 2 Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: step 3, image 2 of 2
    • Remove the screw holding the RAM cover with a PH1 screwdriver.
    • Remove the RAM cover.
  4. Toshiba Satellite A210 Optical Disc Drive Replacement: step 4, image 1 of 3 Toshiba Satellite A210 Optical Disc Drive Replacement: step 4, image 2 of 3 Toshiba Satellite A210 Optical Disc Drive Replacement: step 4, image 3 of 3
    • Push outwards on the metal tabs to release the RAM.
    • Remove the RAM. Some force may be needed.
    • Be careful not to touch the gold pins on the RAM chips as there may be a build-up of static electricity. This can fry the parts of the chip that houses memory.
  5. Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: step 5, image 1 of 3 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: step 5, image 2 of 3 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: step 5, image 3 of 3
    • Use a PH0 screwdriver to remove the screw holding the optical drive in place.
    • Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
    • The optical drive will then slide out.
Bret Wilson
274 Reputation
1 Guide authored
Cal Poly, Team 17-5, Regan Spring 2013 Member of Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
4 Members
18 Guides authored
One Comment
Question : if i this will my screen start working ng again
jessica johnson - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,598
