Toshiba Satellite A105-S4284 RAM Replacement
  1. Toshiba Satellite A105-S4284 RAM Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite A105-S4284 RAM Replacement, Battery: step 1, image 2 of 2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 RAM Replacement, RAM: step 2, image 1 of 2 Toshiba Satellite A105-S4284 RAM Replacement, RAM: step 2, image 2 of 2
    • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
    • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  3. Toshiba Satellite A105-S4284 RAM Replacement: step 3, image 1 of 2 Toshiba Satellite A105-S4284 RAM Replacement: step 3, image 2 of 2
    • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  4. Toshiba Satellite A105-S4284 RAM Replacement: step 4, image 1 of 3 Toshiba Satellite A105-S4284 RAM Replacement: step 4, image 2 of 3 Toshiba Satellite A105-S4284 RAM Replacement: step 4, image 3 of 3
    • Using your fingers, release the tabs on both ends of the RAM.
    • Pull the RAM out.
    • The other RAM is released in the same manner.
pfedigan
11 Reputation
4 Guides authored
Cal Poly, Team 2-23, Maness Spring 2013 Member of Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 Members
13 Guides authored
One Comment
how to remove a bios passcode off of a Toshiba Satellite a105 s4374 laptop
simeon cole - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 2,051
