Toolcraft ST-50D solder station Disassembly
  1. Toolcraft ST-50D solder station Disassembly, So looks the solder station.: step 1, image 1 of 1
    • I think you can disassembly other models of Toolcraft ST solder stations 50/80/100 analog or digital the same way.
  2. Toolcraft ST-50D solder station Disassembly, Put the solder station on the back.: step 2, image 1 of 1
    • There are two holes with screws on the bottom side (green circles on the picture) and the 2-nd pair of screws is under the two rubbery "legs" (red circles).
  3. Toolcraft ST-50D solder station Disassembly, Unglue the two "legs"...: step 3, image 1 of 1
    • ... by nails or by flat screwdriver and you will see the second pair of holes with screws.
  4. Toolcraft ST-50D solder station Disassembly, Unscrew the screws ...: step 4, image 1 of 1
    • ... by Phillips #1 screwdriver and you can open the body of the solder station.
  5. Toolcraft ST-50D solder station Disassembly: step 5, image 1 of 1
    • The cables connected to switch: ON is Up , from inside: 1) RED + BLUE 2) BROWN
  6. Toolcraft ST-50D solder station Disassembly: step 6, image 1 of 1
    • From inside.
Martin Kubica
822 Reputation
1 Guide authored
4 Guide Comments
Hi! Unfortunately, I have stupidly pulled off the contact sockets of the switch when disassembling my station. But I did not notice how they were originally connected. Could you please take a look and maybe take a picture of how the contacts are connected to the switch? I thank you in advance.
omanoman - Reply
Hi.
So I added a picture of cables connected to the switch. ON position of the switch is Up, the cables are from inside of the solder station.
Martin Kubica
Martin Kubica - Reply
Hello Martin, really appreciate your guide but do you have a photo of the back of the board with all the connections? I took it apart but did not take note of which connector the White, Blue and Red/Black wires went to. Its not clear on the photos above, would be hugely appreciated. Thanks!
Michael Telatynski - Reply
здравствуйте помагите найти на нее нагревательный элементяя даже не знаю какой должен быть спасибо
Павел Vor - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 37
All Time: 2,209
