Shop the Holiday Gift Guide
Tokina AT-X Pro 80-200mm Focus repair
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
91
All Time:
1,744
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 hours
Difficulty: Very difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
A lot of the screws are fastened with Loctite.
You need soldering skills.
Tools
    1. Tokina AT-X Pro 80-200mm Focus repair, Tokina autofocus repair: step 1, image 1 of 1
      Tool used on this step:
      Buy
      • Pick up your iFixit Toolkit and some tweezers.
      Ask FixBot
    2. Tokina AT-X Pro 80-200mm Focus repair: step 2, image 1 of 1
      • bit: 1.5
      • quantity: 3
      • screws No. 1
      • item 1
      • remove item 1
      Ask FixBot
    3. Tokina AT-X Pro 80-200mm Focus repair: step 3, image 1 of 1
      • Pick Lens No. 1 at the two outer notches and rotate it counter clockwise. Be not surprised that you need quite some force to loose it.
      • item 2
      • remove item 2
      Ask FixBot
    4. Tokina AT-X Pro 80-200mm Focus repair: step 4, image 1 of 2 Tokina AT-X Pro 80-200mm Focus repair: step 4, image 2 of 2
      • bit: PH00
      • quantity: 3
      • item 3
      • screws No. 2
      • remove item 3.
      Ask FixBot
    5. Tokina AT-X Pro 80-200mm Focus repair: step 5, image 1 of 2 Tokina AT-X Pro 80-200mm Focus repair: step 5, image 2 of 2
      • bit: PH00
      • quantity: 2
      • screws No. 3
      • item No. 4
      • loose item 4
      Ask FixBot
    6. Tokina AT-X Pro 80-200mm Focus repair: step 6, image 1 of 2 Tokina AT-X Pro 80-200mm Focus repair: step 6, image 2 of 2
      • bit: PH0
      • quantity: 3
      • screws No. 4
      • item 5
      • remove item 5
      Ask FixBot
    7. Tokina AT-X Pro 80-200mm Focus repair: step 7, image 1 of 1
      • bit: PH0
      • quantity: 2
      • screws No. 5
      • item 6+7
      • remove item 6+7
      Ask FixBot
    8. Tokina AT-X Pro 80-200mm Focus repair: step 8, image 1 of 2 Tokina AT-X Pro 80-200mm Focus repair: step 8, image 2 of 2
      • bit: PH0
      • quantity: 3
      • screws No. 6
      • item 8
      • remove item 8
      Ask FixBot
    9. Tokina AT-X Pro 80-200mm Focus repair: step 9, image 1 of 2 Tokina AT-X Pro 80-200mm Focus repair: step 9, image 2 of 2
      • bit: PH0
      • quantity: 2
      • screws No. 7
      • item No. 9
      • remove item 9 very carefully!
      Ask FixBot
    10. Tokina AT-X Pro 80-200mm Focus repair: step 10, image 1 of 2 Tokina AT-X Pro 80-200mm Focus repair: step 10, image 2 of 2
      • item 10 (plastic foil)
      • remove item 10
      Ask FixBot
    11. Tokina AT-X Pro 80-200mm Focus repair: step 11, image 1 of 1
      • bit: PH0
      • quantity: 4
      • screws No. 8
      Ask FixBot
    12. Tokina AT-X Pro 80-200mm Focus repair, Soldering!: step 12, image 1 of 1
      • desolder these six joints.
      • keep a lot of attention for that loosen flexibel printed circuit (FPC). It leads to the shutter inside the lens. So be careful not to damage it. Otherwise the shutter won't work!
      Ask FixBot
    13. Tokina AT-X Pro 80-200mm Focus repair: step 13, image 1 of 2 Tokina AT-X Pro 80-200mm Focus repair: step 13, image 2 of 2
      • bit: PH0
      • quantity: 3
      • screws No. 9
      • item 11
      • Under the FPC ring you'll find the screws. Be careful not to damage the FPC!
      • Loose item 11
      Ask FixBot
    14. Tokina AT-X Pro 80-200mm Focus repair: step 14, image 1 of 3 Tokina AT-X Pro 80-200mm Focus repair: step 14, image 2 of 3 Tokina AT-X Pro 80-200mm Focus repair: step 14, image 3 of 3
      • bit: PH0
      • quantity: 2
      • screws No. 10
      • item 11
      • Now, remove item 11.
      Ask FixBot
    15. Tokina AT-X Pro 80-200mm Focus repair: step 15, image 1 of 1
      • item 12
      • remove item 12
      Ask FixBot
    16. Tokina AT-X Pro 80-200mm Focus repair: step 16, image 1 of 3 Tokina AT-X Pro 80-200mm Focus repair: step 16, image 2 of 3 Tokina AT-X Pro 80-200mm Focus repair: step 16, image 3 of 3
      • bit: PH0
      • quantity: 3
      • screws No. 11
      • item 13
      • remove item 13
      Ask FixBot
    17. Tokina AT-X Pro 80-200mm Focus repair: step 17, image 1 of 3 Tokina AT-X Pro 80-200mm Focus repair: step 17, image 2 of 3 Tokina AT-X Pro 80-200mm Focus repair: step 17, image 3 of 3
      • bit: PH0
      • quantity: 6
      • screws No. 12
      • item 14
      • You do not have to loosen the screw in the notch.
      • remove item 14
      Ask FixBot
    18. Tokina AT-X Pro 80-200mm Focus repair: step 18, image 1 of 1
      • bit: PH0
      • quantity: 4
      • screws No 13
      • item 15
      Ask FixBot
    19. Tokina AT-X Pro 80-200mm Focus repair: step 19, image 1 of 1
      • bit: PH0
      • quantity: 2
      • screws No. 14
      • item 16
      Ask FixBot
    20. Tokina AT-X Pro 80-200mm Focus repair: step 20, image 1 of 3 Tokina AT-X Pro 80-200mm Focus repair: step 20, image 2 of 3 Tokina AT-X Pro 80-200mm Focus repair: step 20, image 3 of 3
      • bit: 2
      • quantity: 2
      • screws No. 15
      • item 16
      • remove item 16
      Ask FixBot
    21. Tokina AT-X Pro 80-200mm Focus repair: step 21, image 1 of 2 Tokina AT-X Pro 80-200mm Focus repair: step 21, image 2 of 2
      • bit: PH0
      • quantity: 6
      • screws No. 16
      • item 17 & 18
      • separate item 17 from 18
      Ask FixBot
    22. Tokina AT-X Pro 80-200mm Focus repair: step 22, image 1 of 1
      • bit: PH0
      • quantity: 4
      • screws No. 17
      • item 19 & 20
      • remove item 19
      • then remove item 20
      Ask FixBot
    23. Tokina AT-X Pro 80-200mm Focus repair: step 23, image 1 of 1
      • As you can see on the picture there is a lot of dirt in the winding of item 20. Also there were some sand particles. These damaged the windings so that I had to sand it. Be sure to clean it in detail afterwards and do not apply any grease or oil because it would increase the rotating force. That will impact the autofocus mechanism badly.
      Ask FixBot
    24. Tokina AT-X Pro 80-200mm Focus repair, additional/optional step: step 24, image 1 of 1
      • After you cleaned the focus ring, check whether item 20 rotates smoothly. If not you could clean it, too. But that means a lot of additional work because there are nearly 100 bearing balls.
      • item 21 is fixed with loctite to item 18. Use a cutter knife or similar to cut it.
      • grab item 21 at the two notches and rotate it counterclockwise to remove it.
      • Now item 20 is also loosened. Before you remove it be sure that the bearing balls that will fall out will not fall from your desk.
      Ask FixBot
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Author
with
Sakul
379 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 91
All Time: 1,744
