TiVo Series 2 TCD540080 Cooling Fan Replacement
  1. TiVo Series 2 TCD540080 Cooling Fan Replacement, Removal of TiVo Series 2 TCD540080 Case: step 1, image 1 of 1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Cooling Fan Replacement: step 2, image 1 of 1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Cooling Fan Replacement: step 3, image 1 of 2 TiVo Series 2 TCD540080 Cooling Fan Replacement: step 3, image 2 of 2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Cooling Fan Replacement, Cooling Fan: step 4, image 1 of 1
    • The fan is held in by four T15 screws on the rear of the device.
  5. TiVo Series 2 TCD540080 Cooling Fan Replacement: step 5, image 1 of 2 TiVo Series 2 TCD540080 Cooling Fan Replacement: step 5, image 2 of 2
    • Take the wound red and black wires coming from the fan and follow them back to the logic board.
    • Unplug the connector from the motherboard.
  6. TiVo Series 2 TCD540080 Cooling Fan Replacement: step 6, image 1 of 2 TiVo Series 2 TCD540080 Cooling Fan Replacement: step 6, image 2 of 2
    • Pull the fan towards the front and out of the TiVo unit.
Svyatoslav Markeyev
135 Reputation
5 Guides authored
Cal Poly, Team 33-79, Johann Spring 2010 Member of Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 5,237
