Thymio II Disassembly
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
81
All Time:
947
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this disassembly, we’ll take a closer look at the Thymio II’s internal components and how you can completely remove every part of it. Whether you're looking to repair, modify, or simply understand how this little robot is built, this guide will walk you through every step of disassembly.
Parts
Tools
    1. Thymio II Disassembly, Thymio II Disassembly: step 1, image 1 of 1
      • The Thymio II is composed of a top and bottom cover.
      Ask FixBot
    2. Thymio II Disassembly, Unscrewing the top cover: step 2, image 1 of 1
      • The first step is to remove the four M3x10 Phillips screws from the bottom of the Thymio chassis.
      Ask FixBot
    3. Thymio II Disassembly, Opening up the Thymio II: step 3, image 1 of 3 Thymio II Disassembly, Opening up the Thymio II: step 3, image 2 of 3 Thymio II Disassembly, Opening up the Thymio II: step 3, image 3 of 3
      • Once the screws are removed you simply need to turn the thymio around and pop the top part of the case.
      • Be careful as the speaker is still connect to the PCB so don't pull too hard.
      Ask FixBot
    4. Thymio II Disassembly, Disconnecting the speaker: step 4, image 1 of 3 Thymio II Disassembly, Disconnecting the speaker: step 4, image 2 of 3 Thymio II Disassembly, Disconnecting the speaker: step 4, image 3 of 3
      • Now grab some tweezers or with your fingers disconnect the speaker cable. You should now have two seperate pieces, the top case and the bottom one.
      Ask FixBot
    5. Thymio II Disassembly, Removing the PCB: step 5, image 1 of 3 Thymio II Disassembly, Removing the PCB: step 5, image 2 of 3 Thymio II Disassembly, Removing the PCB: step 5, image 3 of 3
      • To remove the PCB, take it between your hands or with one finger in the pen hole.
      • Tilt and lift the PCB.
      • Be careful as the battery and motor cables are still attached.
      Ask FixBot
    6. Thymio II Disassembly, Removing motor and battery cables: step 6, image 1 of 2 Thymio II Disassembly, Removing motor and battery cables: step 6, image 2 of 2
      • After lifting the PCB, carefully remove the cables one by one with tweezers or your fingers.
      Ask FixBot
    7. Thymio II Disassembly, Removing the wheels: step 7, image 1 of 2 Thymio II Disassembly, Removing the wheels: step 7, image 2 of 2
      • Now that the PCB is out of the way, we can see the motors and the battery.
      • First we need to remove the main M2x8 Phillips screw that holds the wheel.
      • This will reveal the M3x20 Phillips screw that holds the motor to the chassis which needs to be removed in order to remove the motors.
      Ask FixBot
    8. Thymio II Disassembly, Removing the motors: step 8, image 1 of 3 Thymio II Disassembly, Removing the motors: step 8, image 2 of 3 Thymio II Disassembly, Removing the motors: step 8, image 3 of 3
      • Now that the motors are free, we can simply take a prying tool and twist the motor free.
      • The motor axle is still sticking out the chassis so don't force it out if you feel some resistance.
      Ask FixBot
    9. Thymio II Disassembly, Removing the battery: step 9, image 1 of 2 Thymio II Disassembly, Removing the battery: step 9, image 2 of 2
      • The battery is glued to the chassis with an adhesive pad. To remove the battery, use a prying tool to get under the adhesive pad and remove it.
      • Only use the prying tool on the adhesive pad, not the battery itself.
      Ask FixBot
    10. Thymio II Disassembly, Finished disassembly: step 10, image 1 of 1
      • This concludes the Thymio II assembly as shown here with all its parts.
      Ask FixBot
Finish Line
2 other people completed this guide.
Alexandre Aires Viegas
1,686 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 81
All Time: 947
