Introduction
Replacing unresponsive R2 & L2 buttons on the throttle will help with game play.
Parts
No parts required.
  1. Be sure to disconnect the controller from the power source before disassembling.
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Be sure to disconnect the controller from the power source before disassembling.
    • Using your hands, pull away the panel from the throttle.
    • Remove the two 7 mm J1 JIS head screws from the panel covering the buttons.
    • Pull the panel that is covering the R2 button away from the throttle.
    • Carefully push the R2 button from the outside of the panel.
    • Be cautious of the spring attached to the button as it can be easily lost.
    • Remove the two 4 mm J1 JIS head screws from the panel covering the L2 button.
    • Carefully push the L2 button from the outside of the panel.
Crystal Nguyen
431 Reputation
4 Guides authored
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Member of CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 18
All Time: 130
