ThinkPad T420 Keyboard Replacement
  1. ThinkPad T420 Keyboard Replacement, Find your keyboard FRU: step 1, image 1 of 3 ThinkPad T420 Keyboard Replacement, Find your keyboard FRU: step 1, image 2 of 3 ThinkPad T420 Keyboard Replacement, Find your keyboard FRU: step 1, image 3 of 3
    • Each country has a different keyboard FRU part number. Refer to the guide photos or the Lenovo HMM if you live outside of the US.
    • The old part can also be used as a reference.
  2. ThinkPad T420 Keyboard Replacement, Remove the battery: step 2, image 1 of 3 ThinkPad T420 Keyboard Replacement, Remove the battery: step 2, image 2 of 3 ThinkPad T420 Keyboard Replacement, Remove the battery: step 2, image 3 of 3
    • Remove the battery. Push the locking tab to the unlocked position.
    • Once the battery is unlocked, hold the battery release tab in and pull the battery out.
  3. ThinkPad T420 Keyboard Replacement, Remove the RAM door: step 3, image 1 of 3 ThinkPad T420 Keyboard Replacement, Remove the RAM door: step 3, image 2 of 3 ThinkPad T420 Keyboard Replacement, Remove the RAM door: step 3, image 3 of 3
    • WWAN ready systems ship with antenna covers over these cables. Someone installed a WLAN card in this T420 which disabled the better card and was removed.
    • To remove the RAM door, use a Phillips #0 bit. Unscrew the RAM door and set the screw aside in a safe location.
    • To remove the RAM door, pull it off from the side. This can be done with a plastic pry tool or your fingernail.
  4. ThinkPad T420 Keyboard Replacement, Remove the keyboard screw: step 4, image 1 of 2 ThinkPad T420 Keyboard Replacement, Remove the keyboard screw: step 4, image 2 of 2
    • A magnetic screwdriver is highly recommended. This screw has a tendency to not come out unless a magnet is used.
    • To remove the keyboard, remove the final screw. This will be located under the RAM door.
  5. ThinkPad T420 Keyboard Replacement, Remove the keyboard: step 5, image 1 of 3 ThinkPad T420 Keyboard Replacement, Remove the keyboard: step 5, image 2 of 3 ThinkPad T420 Keyboard Replacement, Remove the keyboard: step 5, image 3 of 3
    • Open the laptop.
    • To remove the keyboard, release the keyboard hooks using a plastic pry tool.
    • Once the keyboard is loose, remove it from the chassis.
  6. ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: step 6, image 1 of 3 ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: step 6, image 2 of 3 ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: step 6, image 3 of 3
    • If you have a can of compressed air available, some of the dust can be removed at this point. Further disassembly is required for a full cleaning.
    • Disconnect the keyboard from the motherboard. Use a plastic pry tool for this step.
  7. ThinkPad T420 Keyboard Replacement, Keyboard re-installation: step 7, image 1 of 3 ThinkPad T420 Keyboard Replacement, Keyboard re-installation: step 7, image 2 of 3 ThinkPad T420 Keyboard Replacement, Keyboard re-installation: step 7, image 3 of 3
    • Reconnect the keyboard to the motherboard. Once connected, slide the top (volume controls) in first.
    • Once the top of the keyboard is pushed in, slide the keyboard down to re-engage the lower clips until they are not visible.
    • Replace the silver screw and RAM door.
Finish Line
7 other people completed this guide.
Nick
88,851 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,532 Guides authored
3 Comments
Excellent guide, I like the detail specifying screw bits
Jakezxz1 - Reply
replacing the key went good but can’t get in because of password. need help
Steve Jacofsky - Reply
I love how simply disassemby are in those old ThinkPads <3
Ziobro - Reply
Past 24 Hours: 5
Past 7 Days: 36
Past 30 Days: 147
All Time: 11,859
