Introduction
Use this guide to replace a broken LCD in your ThinkPad 13 Chromebook, or upgrade the HD display to a FHD display on an entry-level model.
Use a Size 0 Philips screwdriver to loosen the nine screws on the bottom of the case. They will not come out entirely, but you will feel when they are loose enough.
You will need to remove the rubber pads from the bottom three screws using a pair of tweezers.
Insert an opening pick into the space between the lower case and the chassis.
Slide the opening pick around the case, pushing inward to release the clips securing the lower case. You should feel and hear the clip pop free.
Use a spudger or other plastic tool to push the battery connector in the direction of the arrow, removing it from its socket.
Use the plastic opening tool to pull the panel forward and release it from the display assembly.
You may need a little help from your fingers for the thicker bottom bezel.
Open the laptop completely to 180 degrees and lay it flat.
Remove the four screws that secure the LCD panel to the plastic. Do not confuse these for the screws securing the hinge to the display assembly.
Peel off the sticker securing the display cable to the LCD panel.
Using the flat end of a spudger, lift the cable lock and gently remove the display cable from the LCD panel.
