An easy way to replace a broken rear glass on an iPhone XR
Video Overview
  1. An easy way to replace a broken rear glass on an iPhone XR, Preparing the rear glass for removal: step 1, image 1 of 2 An easy way to replace a broken rear glass on an iPhone XR, Preparing the rear glass for removal: step 1, image 2 of 2
    • Insert the phone into the Laser Separator "Blue Light" to treat the rear glass with the laser in order to easily remove it later.
  2. An easy way to replace a broken rear glass on an iPhone XR, Removal of the rear glass cover: step 2, image 1 of 2 An easy way to replace a broken rear glass on an iPhone XR, Removal of the rear glass cover: step 2, image 2 of 2
    • To remove the real glass we will need to use a sharp blade.
    • After the laser treatment the rear glass will be very easy to remove, which is why we chose to use the laser separator. This makes the iPhone dissasembly considerably less difficult.
    • This is what the phone looks like after removing the rear panel.
  3. An easy way to replace a broken rear glass on an iPhone XR, Cleaning: step 3, image 1 of 3 An easy way to replace a broken rear glass on an iPhone XR, Cleaning: step 3, image 2 of 3 An easy way to replace a broken rear glass on an iPhone XR, Cleaning: step 3, image 3 of 3
    • Before cleaning the black objects we will need to use a small spatula to clear out the broken glass along the edge of the panel.
    • After completing this step, use a clean cloth and isopropyl alcohol to clean the black objects.
    • Now the cleaning is done, we're trying to keep the white adhesive. This is the key to restoring the original thickness of the iPhone.
  4. An easy way to replace a broken rear glass on an iPhone XR, Adding new adhesive: step 4, image 1 of 2 An easy way to replace a broken rear glass on an iPhone XR, Adding new adhesive: step 4, image 2 of 2
    • In this step, we will add fresh adhesive along the edges, and inside empty spaces.
    • The photo shows the rear panel after adding the adhesive.
  5. An easy way to replace a broken rear glass on an iPhone XR, Installing the rear glass: step 5, image 1 of 2 An easy way to replace a broken rear glass on an iPhone XR, Installing the rear glass: step 5, image 2 of 2
    • Install the new glass, then use four screen vise clamps to apply pressure.
    • The replacement process is complete. This is the final result; this phone is looking as perfect as an original phone.
If you are looking for the best way to replace the rear glass in your mobile phone, you can find out if this method will be any good for you.
2 other people completed this guide.
Special thanks to these translators:
ru en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
FORWARD Lab
1,474 Reputation
9 Guides authored
One Comment
well… that’s good! Repair become so easy, since everybody have a blue-laser-machine at home
Alex Nox - Reply
Past 24 Hours: 21
Past 7 Days: 101
Past 30 Days: 503
All Time: 20,637
