Introduction
This tutorial will help you replace the battery of your Pave Parisien
  1. Remove the protective grille by lifting one of the four corners. Remove the protective grille by lifting one of the four corners.
    • Remove the protective grille by lifting one of the four corners.
  2. Remove the four screws using a m4 allen wrench Remove the four screws using a m4 allen wrench
    • Remove the four screws using a m4 allen wrench
  3. Pull the speaker out a bit to access the connectors With light gentle movements, pull and disconnect the two cables from the connections
    • Pull the speaker out a bit to access the connectors
    • With light gentle movements, pull and disconnect the two cables from the connections
  4. Pull the speaker completely out of the recessed compartment Gently pull the board behind the speaker out and place on a flat surface
    • Pull the speaker completely out of the recessed compartment
    • Gently pull the board behind the speaker out and place on a flat surface
  5. Disconnect the battery connector from the board Be careful to pull gently using a small screwdriver to pry up the clip, then apply gentle pressure Be careful to pull gently using a small screwdriver to pry up the clip, then apply gentle pressure
    • Disconnect the battery connector from the board
    • Be careful to pull gently using a small screwdriver to pry up the clip, then apply gentle pressure
  6. Push the battery from the rear towards the opening where the wires are The battery is out and now it can be changed
    • Push the battery from the rear towards the opening where the wires are
    • The battery is out and now it can be changed
  7. Pass the connector through the space that is indicated for it Pass the connector through the space that is indicated for it Pass the connector through the space that is indicated for it
    • Pass the connector through the space that is indicated for it
  8. The texture of this surface is different from the other three faces. Orient yourself to how it fits correctly.
    • The texture of this surface is different from the other three faces. Orient yourself to how it fits correctly.
  9. First connect the positive and negative wires, then slide the speaker in the enclosure in the right orientation First connect the positive and negative wires, then slide the speaker in the enclosure in the right orientation
    • First connect the positive and negative wires, then slide the speaker in the enclosure in the right orientation
  10. Finally replace the speaker grill: your Pave Parisien is ready to use!
    • Finally replace the speaker grill: your Pave Parisien is ready to use!
Finish Line
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Le Pavé Parisien
529 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 100
