Texas Instruments TI-83 Plus Motherboard & Screen Replacement
  1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Backup Battery: step 1, image 1 of 2 Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Backup Battery: step 1, image 2 of 2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: step 2, image 1 of 1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: step 3, image 1 of 1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Back Case: step 4, image 1 of 1
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  5. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: step 5, image 1 of 2 Texas Instruments TI-83 Plus Motherboard & Screen Replacement: step 5, image 2 of 2
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
  6. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Motherboard & Screen: step 6, image 1 of 2 Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Motherboard & Screen: step 6, image 2 of 2
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
  7. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: step 7, image 1 of 2 Texas Instruments TI-83 Plus Motherboard & Screen Replacement: step 7, image 2 of 2
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
20 other people completed this guide.
Kevin
479 Reputation
1 Guide authored
Cal Poly, Team 18-37, Regan Fall 2012 Member of Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Members
5 Guides authored
15 Comments
Does anyone have any advice on acquiring replacement screens for the TI series? I was considering buying broken TIs on e-bay, but that may be unreliable.
Neil Cammardella - Reply
Fixing TI83+'s is becoming addictive. Google Cemetech Forum on the net and see how he removes the screen from the Mother Board and solders wires permanently. I might add that he tests for resistance (ohms) first to determine if in fact that is where the problems exist. If I read between the lines, he tends to think that the screen/mother board ribbon cable is the primary culprit behind problems with the TI83's
shrinertom@yahoo.com
shrinertom -
My TI-83 Plus, the screen has turned Black, like to know where to send it to have it repaired e-mail address, (BagManOne@ecite.com)
Richard Brown - Reply
Nothing is broken, the screen has turned Black, need to send it off and have it fixed, I can not do it my self because of the condition of my hands
Richard Brown -
It may not be broken. Try adjusting the screen contrast down.
Matthew Johnson -
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 89
All Time: 49,150
