Introduction
If your back case is cracked or broken this guide will show you how it is removed and replaced.
Remove the 5mm Philips #00 screw holding backup battery cover.
Remove the backup battery cover.
Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
