Texas Instruments TI-5130 Printer Unit Replacement
  1. Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: step 1, image 1 of 2 Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: step 1, image 2 of 2
    • Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
  2. Texas Instruments TI-5130 Printer Unit  Replacement: step 2, image 1 of 1
    • Flip the calculator back over and remove the top cover.
  3. Texas Instruments TI-5130 Printer Unit  Replacement: step 3, image 1 of 1
    • Disconnect the printing unit from the motherboard by pulling up on the connector – located in the bottom left of the motherboard.
  4. Texas Instruments TI-5130 Printer Unit  Replacement: step 4, image 1 of 1
    • Remove the ink cartridge by pushing the tab back then lifting it out to gain access to the screw that holds the printer in place.
  5. Texas Instruments TI-5130 Printer Unit  Replacement: step 5, image 1 of 2 Texas Instruments TI-5130 Printer Unit  Replacement: step 5, image 2 of 2
    • Using a PH1 screwdriver remove the 10mm screw that holds down the printer unit.
    • Remove the printer unit by lifting it up.
3 other people completed this guide.
Shannon Perkins
652 Reputation
3 Guides authored
2 Comments
wehre did you buy the replacement printer
Tino ullrich - Reply
what sources are there for TI-5130 printer unit?
Norman Todd - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 10
All Time: 2,278
