Introduction
This guide will show, step by step, the battery replacement for the TI-30Xa scientific calculator.
Locate the six screws on the back of the calculator.
With a Phillips #1 screwdriver, loosen and remove the screws.
Find the two notches at the top of the calculator.
Insert a flat-head screwdriver into one of the notches and carefully pry open the top end of the case.
Locate where the case is still attached at the sides.
Insert the flat-head screwdriver into one side where the gap has widened.
Now gently pry apart the sides of the case.
The two LR44 batteries are located at the top.
Slide the flat-head screwdriver underneath each battery and they will easily pop out.
