Tefal kettle defective: On Switch no longer works
  1. Tefal kettle defective: On Switch no longer works, Disassemble the kettle: step 1, image 1 of 1
    • Remove the Lid
    • Remove the two screws (on either side of the handle, on top)
    • Remove the Handle
    • The linkage that leads down from the 'switch' has a kind of 'joint' made of flexible plastic
    • It's obvious that something like this doesn't last forever..... bend it back and forth 1000 times and it breaks.....
    • Planned obsolescence?
  2. Tefal kettle defective: On Switch no longer works, Make replacement 'joints': step 2, image 1 of 1
    • Bend 2 new joints using copper wire
  3. Tefal kettle defective: On Switch no longer works, Drill holes: step 3, image 1 of 1
    • Drill two 0.8 mm holes, in each of the 4 plastic ends
  4. Tefal kettle defective: On Switch no longer works, Install the new joints: step 4, image 1 of 1
    • Thread the wires through the holes and adjust them.
    • To make room for them, shorten each plastic tip by 1 mm
  5. Tefal kettle defective: On Switch no longer works, Test: step 5, image 1 of 1
    • Attention, to test; this little red pin has to be pushed in... otherwise the switch won't click into place
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
Gottfried Silberhorn
1,429 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 61
All Time: 501
