How to Rewire a Lamp
  1. How to Rewire a Lamp, Cord: step 1, image 1 of 3 How to Rewire a Lamp, Cord: step 1, image 2 of 3 How to Rewire a Lamp, Cord: step 1, image 3 of 3
    • Before starting the process, remove the lamp shade and bulb by hand.
    • Make sure the lamp is unplugged to avoid the risk of electrocution.
  2. How to Rewire a Lamp: step 2, image 1 of 3 How to Rewire a Lamp: step 2, image 2 of 3 How to Rewire a Lamp: step 2, image 3 of 3
    • Loosen the setscrew with the screwdriver so you can unscrew the socket base.
    • Unscrew the socket base from the threaded tube with your hand.
  3. How to Rewire a Lamp: step 3, image 1 of 3 How to Rewire a Lamp: step 3, image 2 of 3 How to Rewire a Lamp: step 3, image 3 of 3
    • With your hand, pry the socket shell out of its base.
    • Remove the socket with your hand and then cut the wires with the wire cutters.
    • The neutral wire connects to the wide plug blade and is distinguished from the hot wire by ribs, color, printing, or indentations in the plastic insulation.
  4. How to Rewire a Lamp: step 4, image 1 of 2 How to Rewire a Lamp: step 4, image 2 of 2
    • Strip off 1/2" of the insulation with the wire stripper and twist the wire strands together by hand.
    • If you pull off any wire strands while stripping, cut back the cord with the Diagonal cutter.
  5. How to Rewire a Lamp: step 5, image 1 of 3 How to Rewire a Lamp: step 5, image 2 of 3 How to Rewire a Lamp: step 5, image 3 of 3
    • By hand, tie an underwriters knot in the cord.
    • Also by hand, connect the wires by wrapping them clockwise around the screws and tighten and connect the neutral wire to the silver screw.
    • An underwriter's knot prevents the wires from pulling out of the screw terminals when cord is tugged. ( The entire process of tying an underwriter knot can be done by hand . Form a loop using the first wire. Then, form a loop around the first wire and pass the tail through its loop. The strain on the cable is now taken by the knot.)
  6. How to Rewire a Lamp: step 6, image 1 of 3 How to Rewire a Lamp: step 6, image 2 of 3 How to Rewire a Lamp: step 6, image 3 of 3
    • By hand, pull the excess cord down through the lamp.
    • Still using your hand, slip the insulation sleeve and socket shell over the socket and snap the shell into the base.
Finish Line
2 other people completed this guide.
Molly
119 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 24
All Time: 1,252
