Introduction
A working battery can last up to 6 hours at a time on a normal volume level. A replacement battery can be ordered online.
Get a replacement battery from the TDK company. The battery part number is E23-00059-01.
Obtain the screwdriver and the T09 (Torx) bit from the iFixit toolkit and assemble them together.
Use the T09-bit screwdriver to remove the two 8-mm torx screws on the bottom strip of the speaker.
After this step, you can slide the cover to the left and remove it. The battery is directly underneath!
So glad I read this comment, so EASY..
Thank you..
Just gotta find a battery now! -
Remove the one 7-mm Phillips head screw located on the lower left of the front of the speaker with the PH1-bit screwdriver.
Once you have found the white plug, gently grip the colored wires and carefully pull to remove the white plug from the speaker.
Avoid passive voice; instead, use active voice (like you did in step 16).
Thank you !!!!
Just completed this process and you actually should not have to completely remove the backing to get the battery out. Once the front 9 screws are removed the backing can be slightly separated (pulled back) from the central housing and the bottom plate that covers the batter should just fall right off. Replace the battery through the bottom, slide the cover plate back in and put all the screws back.
9 other people completed this guide.
2 Comments
This procedure is totally unnecessary! TDK has much simpler instructions. http://downloads.imationsupport.com/lor/...
