Introduction
Built-in AirMac Extreme 802.11g card instructions
Overseas this is sold under the name of AirPort, but it Japan it is known as AirMac. The reason for this difference in names is the difference in trademark registration overseas versus Japan.
  1. Rotate the battery latch  90°  in clockwise with a coin.
    • Rotate the battery latch 90° in clockwise with a coin.
  2. Lift the hatch, and remove it from the laptop
    • Lift the hatch, and remove it from the laptop
  3. Please remove the three Phillips screws equally spaced on the partition of the battery on the back side of the main unit.
    • Please remove the three Phillips screws equally spaced on the partition of the battery on the back side of the main unit.
    • Since the screw is fixed to the metal memory cover, there is no worry of losing it.
    • (Translator's Comment) Although I am unable to turn Phillips (Phillips) screws in accordance with the JIS standards sold in Japan, since it does not mean that the shapes are perfectly matched, There is a possibility that it may not be possible to reassemble in the worst case because it is scraped.
    • Drivers for Phillips screws are sold with the notation PHxxx or PH # xxx if going to a home center etc. (x is a number, it is like 000, 00, 0, 1, 2 ... from the smallest tip order). Or you can also purchase it at the iFixit store because it is sold.
  4. Pull the L-shaped RAM cover towards you and remove it from the laptop.
    • Pull the L-shaped RAM cover towards you and remove it from the laptop.
    When reinserting, begin with the tip of the short side - there is a notch that seats into the front edge of the machine that needs to be pushed home before the cover will reseat properly. Near the bend on the long side, there is a locating pin that fits into a hollow in the frame beneath. Once these two things are right, the strip should position properly without any force. The small screws may take some patience to align properly and tighten but this will be much easier if the strip is properly position first, rather than trying to force it.
    Dave Pritlove - Reply
  5. Please remove the following three screws:
    • Please remove the following three screws:
    • One Phillips # 000 screw (screw head: diameter 5 mm, thickness 0.75 mm) of 11 mm in length in the middle of the case is one
    • Two Phillips # 000 screws (screw head: diameter 5 mm, thickness 0.75 mm) with a length of 14.5 mm are two
    • If the screw will get stuck to the case, you can remove the screw by sticking with a magnetic driver.
    • The shortest screw among the three comes in the middle.
  6. Take out the battery and the 3 screws inside the battery compartment.
    • Take out the battery and the 3 screws inside the battery compartment.
    • One 3mm long phillips head #0 screw (Screw diameter: 2.75mm)
    • On either side there are two 4mm long Phillips head #0 screws. (Screw head diameter is 2.27mm)
  7. Please remove the following two screws at both ends of the partition on the right side of the battery. (The screw closer to the battery connector is only fixing the battery connector, so it is not necessary to remove it.)
    • Please remove the following two screws at both ends of the partition on the right side of the battery. (The screw closer to the battery connector is only fixing the battery connector, so it is not necessary to remove it.)
    • Two Phillips # 000 screws (screw head: diameter 4 mm, thickness 0.5 mm) with a length of 6.25 mm are two
  8. Please remove the four screws indicated by the red circle of the image on the partition of the battery on the front side of the main unit. It is the 2nd, 4th, 7th, 9th screw from the left.
    • Please remove the four screws indicated by the red circle of the image on the partition of the battery on the front side of the main unit. It is the 2nd, 4th, 7th, 9th screw from the left.
    • Four Phillips # 000 screws (screw head: 4 mm diameter, 0.4 mm thickness) with a length of 3.25 mm
  9. Please remove the following four screws on the back side of the computer:
    • Please remove the following four screws on the back side of the computer:
    • The long screws are inside and the short screws are outside both ends.
    • There are two Phillips # 00 screws (shank dimension: 2.2 mm in diameter, 2 mm in length) (screw head: 3.2 mm in diameter, 0.5 mm in thickness) with a long 11 mm shank
    • There are two Phillips # 00 screws (shank dimension: 2 mm in diameter, 3.75 mm in length) (screw head: 3.2 mm in diameter, 0.5 mm in thickness) with a shank of 7.25 mm in length
  10. Please remove the two screws on the optical drive side of the computer.
    • Please remove the two screws on the optical drive side of the computer.
    • Phillips # 00 screw with shank of 5.2 mm in length (Shank dimensions: diameter 2.3 mm, length 3.5 mm) (screw head: diameter 3.2 mm, thickness 5 mm)
    • The same screw on the opposite side of the optical drive is the decorative so you do not have to remove it.
    • Since the keyboard and the track pad of the top board are connected with the logic board with the ribbon cable, please never forcibly pull out. The ribbon cable may be torn down.
    • Let's detach the top board on the principle of lever (lever) so that it goes around from the screen side to the front side of the computer. If you use the plastic opening tool or a stiff guitar pick, you can easily remove it.
    • As the top of the optical drive top seems to stick together, please put a guitar pick etc. on both sides of the optical drive that is not sticking first and remove the top board with a lever.
    • After removing the work, the four gray plastic clips holding the keyboard may be disengaged, but please do not rush. There is a part where you put the clip in the corner of CD drive periphery right side corner and there is no problem if you slide the clip into it and set it there.
    While removing the keyboard panel, work around the outside lifting as you go rather than freeing one side and levering up at a steep angle in order to avoid damaging the ribbon connector beneath (removed in next step). There seems to only be a single connector, roughly in the middle of the machine. It lifts off upwards, perpendicular to the circuit board. The single ribbon appears to come from the track pad (this confused me when reassembling as I was unable to find a separate connector for the keyboard - don’t worry, there is only the single connector).
  11. While lifting the top board, please pull the black tab on the connector part of the silver cable upwards and remove the connector. If there is no black tab it is possible to remove the connector from the connector housing by using the spatger with the lever principle.Because this connector is long, please be sure to remove it straight up. Even if you disconnected the cable attached to the top board when removing the top board, please be assured that iFixit sells the cables individually. There is an exchange guide, it can do easily.
    • While lifting the top board, please pull the black tab on the connector part of the silver cable upwards and remove the connector.
    • If there is no black tab it is possible to remove the connector from the connector housing by using the spatger with the lever principle.Because this connector is long, please be sure to remove it straight up.
    • Even if you disconnected the cable attached to the top board when removing the top board, please be assured that iFixit sells the cables individually. There is an exchange guide, it can do easily.
    • How about trying as an opportunity to remove dust, hair, etc while removing the top board? The best is to use a can containing compressed air. If you do it with a solid brush made of building materials (using common animal hair), static electricity will be generated and you can destroy your computer.
    • In reassembling, please confirm that the four gray plastic clips are on the optical drive side of the keyboard. (Please refer to the second image.) Please firmly attach the clip so that the keyboard is securely fixed.
    • To ease the reassembly process, it is better to clip the clip part. Please note that doing with a strong force may cause damage.
    • (Translator's comment) Since it will not be fixed unless you attach it with a strong force when fixing the keyboard, the insertion opening of the optical drive may be distorted with a strong force.
    • There is no worry about being distorted if you put half of the disc such as a DVD and the credit card etc which you no longer need into the insertion opening in half.
  12. Gently remove the 3 signal wires shown in the yellow box First, disconnect the black wire, then the blue wire, then the grey wire.
    • Gently remove the 3 signal wires shown in the yellow box
    • First, disconnect the black wire, then the blue wire, then the grey wire.
    • If your MacBook is a Core 2 Duo Santa Rosa or Penryn core loaded model, there are only two antenna cables. Remove the black wire, then the grey wire.
  13. Remove the following two screws from the AirPort Card:
    • Remove the following two screws from the AirPort Card:
    • One 3mm long Phillips screw
    • One 8mm long Phillips screw
  14. Holding the top of the AirPort Card firmly, remove it by slide it out in the direction towards the screen of the computer.
    • Holding the top of the AirPort Card firmly, remove it by slide it out in the direction towards the screen of the computer.
Finish Line
4 other people completed this guide.
Special thanks to these translators:
jp en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Uhucream
737 Reputation
4 Guides authored
Japanese Translators Member of Japanese Translators
Community
3 Members
9 Guides authored
2 Comments
Great, thanks for the very detailed tutorial, it helps me a lot. Once again I appreciate you. Please continue to bring more tutorials for this series. '''png free'''
Ciara Wright - Reply
This is a really useful guide mainly because of the large number of screws you will see during disassembly. Only the screws mentioned need be removed but, without the guide, there are many more that look like they might need to come out. Thanks.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 55
All Time: 4,990
