Introduction
In this guide you will be required to take off the back cover of the device in order to locate and remove the battery. You will need to use a soldering iron to accomplish this task.
Because this task requires the use of a soldering iron, prior experience with soldering/desoldering will be beneficial.
Wedge the plastic opening tool between the back cover of the device and the front panel.
You will hear a snapping sound as the cover is separated from the body of the device.
Remove the Battery
The battery is secured to the back panel with tape and glue.
Peel back the tape around the battery and discard it.
Tear through the adhesive holding the battery by using the spudger tool.
2 other people completed this guide.
