Introduction
This guide shows you how to mod your super nintendo region free without a switch and with new LED lights.
btw. This mod doesn't work on 1 Chip SNES or SNES Mini.
Remove the two Phillips two 11.6mm screws that connect the front shield to the motherboard.
Tool used on this step:Desoldering Pump$3.99
Remove the Lock Out chip (use the solder gun)
Now you have to put the PIC16F630 Chip into the programmer and Flash the chip with the Super CIC File.
File can be downloaded here: http://sd2snes.de/files/supercic.zip
Bend the pins outwards
Then clip the pins
Use double sided tape and put it on top of the CPU and put the Super CIC on top of the double sided tape.
Pic 1: Solder a wire from Super CIC Pin 12 to PPU1 Pin 24
Pic 2: Solder a wire from Super CIC Pin 14 to SWRAM Pin 64
Pic 3: Solder the 10k Ohm Resistor to the pin 8 (where the old CIC used to be) and to SWRAM Pin 33
Pic 1: Solder a Wire from Super CIC Pin 1 to 4 on the same chip.
Pic 2: Solder a wire from Super CIC Pin 1 to the CPU Pin 1
Pic 3: Solder a wire from Super CIC Pin 13 to the End Point of the Resistor
Pic 1: Sother a wire from Super CIC Pin 2 to S-CLK Pin 6
Pic 2: Sother a wire from Super CIC Pin 11 to Old CIC Pin 10
Pic 3: Sother a wire from Super CIC Pin 10 to Old CIC Pin 1
Pic 1: Solder a wire from Super CIC Pin 9 to Old CIC Pin 2
Pic 2: Solder a wire from Super CIC Pin 8 to Old CIC Pin 11
Pic 3: You've soldered most of the wires now, lets go to the LED Mod
Plug out the controller ports and solder out the LED Light.
Sother on the new LED Light with the middle pin on the left solder hole
Solder 2 wires on the left and right pins on the led light, green wire on the left pin and red wire on the right pin.
After that you should put the wires into one heat shrink tube each, remember to heat the heat shrink tubes when its over the pins.
Then you have to solder the 2k Resistor to the red wire and the 220 ohm Resistor to the green wire.
Then the last thing you need to do is to solder a wire from Super CIC Pin 7 to Pin 14.
You're Now Done! You just need to put your Super Nintendo back together and then you have a Region Free Switchless Super Nintendo!
Green Light (PAL)
Red Light (NTSC) [For American and Japanese Games]
Orange Light (Auto)
These screenshots have been taken by 2 videoes, one from Global Garage and Chips y Bits on YouTube! I made this guide since its a little easier to read a guide with pictures like this instead of watching a 30 min video
3 Comments
Is there some way to get a chip that is already programmed? I don’t have a plan on doing this a lot and the $100 is a bit much at the moment.
Will this same method be used for the PAL version if the console.
