Summer LookOut Duo Motherboard and Display Replacement
  1. Summer LookOut Duo Motherboard and Display Replacement, Battery: step 1, image 1 of 3 Summer LookOut Duo Motherboard and Display Replacement, Battery: step 1, image 2 of 3 Summer LookOut Duo Motherboard and Display Replacement, Battery: step 1, image 3 of 3
    • Flip the device over so the back is facing up.
    • Remove the 9 mm screw using a Phillips #1 screwdriver.
    • Lift the battery panel away from the device.
  2. Summer LookOut Duo Motherboard and Display Replacement: step 2, image 1 of 3 Summer LookOut Duo Motherboard and Display Replacement: step 2, image 2 of 3 Summer LookOut Duo Motherboard and Display Replacement: step 2, image 3 of 3
    • Flip the handheld monitor over and let the battery fall out into your hand.
    • Using angled tweezers, gently remove the plastic wire coupling from the side of the open battery compartment.
    • If the coupling struggles to release, with a loose but firm grip, slightly wiggle the plastic wire coupling back and forth until it releases.
    • Remove the battery from the device.
  3. Summer LookOut Duo Motherboard and Display Replacement, Motherboard and Display: step 3, image 1 of 3 Summer LookOut Duo Motherboard and Display Replacement, Motherboard and Display: step 3, image 2 of 3 Summer LookOut Duo Motherboard and Display Replacement, Motherboard and Display: step 3, image 3 of 3
    • Using the Phillips #00 screwdriver, remove the four 7mm screws from each corner on the back of the handheld monitor.
    • Remove the casing from the back of the handheld monitor.
    • A nylon spudger may be helpful to pry the case open.
    • Using the angled tweezers, gently remove the plastic wire coupling connecting the speaker to the motherboard.
    • The power button may come loose as the case is being removed.
  4. Summer LookOut Duo Motherboard and Display Replacement: step 4, image 1 of 2 Summer LookOut Duo Motherboard and Display Replacement: step 4, image 2 of 2
    • Remove the motherboard and monitor display together and set aside.
Adrianna Piedra
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 96
