Subaru Smart Key Fob Model 14AHK Battery Replacement
  1. Subaru Smart Key Fob Model 14AHK Battery Replacement, Battery: step 1, image 1 of 2 Subaru Smart Key Fob Model 14AHK Battery Replacement, Battery: step 1, image 2 of 2
    • Press the silver button on the back of the key fob.
    • While pressing the silver key, pull out the physical key.
  2. Subaru Smart Key Fob Model 14AHK Battery Replacement: step 2, image 1 of 2 Subaru Smart Key Fob Model 14AHK Battery Replacement: step 2, image 2 of 2
    • Use the physical key to pry and twist the back cover off.
    • Use gentle pressure to avoid breaking the back cover.
  3. Subaru Smart Key Fob Model 14AHK Battery Replacement: step 3, image 1 of 1
    • Remove the control board from the key fob.
    • Keep in mind the direction of the control board as it needs to be reassembled in the same direction.
  4. Subaru Smart Key Fob Model 14AHK Battery Replacement: step 4, image 1 of 1
    • Use a plastic pry tool to lift the battery out of place.
    • Remove the old battery.
    • Use gentle pressure here to avoid breaking the clips that hold the battery in place.
  5. Subaru Smart Key Fob Model 14AHK Battery Replacement: step 5, image 1 of 2 Subaru Smart Key Fob Model 14AHK Battery Replacement: step 5, image 2 of 2
    • Insert the new battery at an angle.
    • Press down on the raised side of the battery until it snaps into place.
  6. Subaru Smart Key Fob Model 14AHK Battery Replacement: step 6, image 1 of 1
    • Reinstall the control board into the key fob with the same orientation as before.
  7. Subaru Smart Key Fob Model 14AHK Battery Replacement: step 7, image 1 of 1
    • Align the back cover and press firmly around the edges to secure it in place.
  8. Subaru Smart Key Fob Model 14AHK Battery Replacement: step 8, image 1 of 1
    • Reinsert the physical key.
  9. Subaru Smart Key Fob Model 14AHK Battery Replacement: step 9, image 1 of 1
    • Test the key fob by pressing a button and looking for a red light to light up in the top left corner.
Finish Line
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 39
Past 30 Days: 62
All Time: 82
