Steam Deck OLED Left Bumper Removal
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Steam Deck OLED Left Bumper Removal, Prepare your Steam Deck for disassembly: step 1, image 1 of 3 Steam Deck OLED Left Bumper Removal, Prepare your Steam Deck for disassembly: step 1, image 2 of 3 Steam Deck OLED Left Bumper Removal, Prepare your Steam Deck for disassembly: step 1, image 3 of 3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down in its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck OLED Left Bumper Removal, Remove the back cover screws: step 2, image 1 of 2 Steam Deck OLED Left Bumper Removal, Remove the back cover screws: step 2, image 2 of 2
    Tool used on this step:
    FixMat
    $31.41
    Buy
    • Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
  3. Steam Deck OLED Left Bumper Removal, Unclip a handle: step 3, image 1 of 3 Steam Deck OLED Left Bumper Removal, Unclip a handle: step 3, image 2 of 3 Steam Deck OLED Left Bumper Removal, Unclip a handle: step 3, image 3 of 3
    • Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
    • If you can't insert your pick here, try along the top or bottom edges of the Steam Deck OLED before sliding it toward the handle.
    • Slide your pick along the edge of the handle to release the clips securing it to the front shell.
  4. Steam Deck OLED Left Bumper Removal, Unclip the top and bottom edges: step 4, image 1 of 3 Steam Deck OLED Left Bumper Removal, Unclip the top and bottom edges: step 4, image 2 of 3 Steam Deck OLED Left Bumper Removal, Unclip the top and bottom edges: step 4, image 3 of 3
    • Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
  5. Steam Deck OLED Left Bumper Removal, Remove the back cover: step 5, image 1 of 3 Steam Deck OLED Left Bumper Removal, Remove the back cover: step 5, image 2 of 3 Steam Deck OLED Left Bumper Removal, Remove the back cover: step 5, image 3 of 3
    • Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
    • Remove the back cover.
  6. Steam Deck OLED Left Bumper Removal, Disconnect the battery: step 6, image 1 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the battery: step 6, image 2 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the battery: step 6, image 3 of 3
    • Grip the battery cable pull tab, located to the left of the battery.
    • Firmly pull the battery cable straight away from the motherboard shield (toward the battery) to disconnect it.
    • This bundled cable is fairly stiff. If you're having trouble, re-grip the pull tab close to the head of the connector and gently walk it side-to-side as you pull.
    • If the cable pull-tab feels fragile or rips during this process, remove the motherboard shield and disconnect the cable using a spudger.
    • When the battery cable comes free, it might push up on the motherboard shield. Don't worry, as this won't damage anything.
  7. Steam Deck OLED Left Bumper Removal, Disconnect the left thumbstick: step 7, image 1 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the left thumbstick: step 7, image 2 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the left thumbstick: step 7, image 3 of 3
    Buy
    • Use the point of a spudger to flip up the small locking flap on the left thumbstick ZIF connector.
    • The pull tab on this connector may be labeled TS.
    • Use tweezers or your fingers to grip the cable's pull tab and slide the connector straight out of its socket to disconnect it.
  8. Steam Deck OLED Left Bumper Removal, Disconnect the interconnect cable: step 8, image 1 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the interconnect cable: step 8, image 2 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the interconnect cable: step 8, image 3 of 3
    Buy
    • Use a spudger to flip up the small white locking flap on the left button board interconnect cable ZIF connector.
    • The pull tab on this connector may be labeled C‑L.
    • Use tweezers or your fingers to grip the cable's pull tab and slide it straight out of its socket to disconnect it.
  9. Steam Deck OLED Left Bumper Removal, Disconnect the left thumbstick: step 9, image 1 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the left thumbstick: step 9, image 2 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the left thumbstick: step 9, image 3 of 3
    • Flip up the small black locking flap on the left thumbstick cable ZIF connector.
    • The pull tab on this connector may be labeled DB.
    • Slide the connector straight out of its socket to disconnect it.
  10. Steam Deck OLED Left Bumper Removal, Disconnect the D-pad: step 10, image 1 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the D-pad: step 10, image 2 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the D-pad: step 10, image 3 of 3
    • Flip up the small locking flap on the D‑pad ZIF connector, located in the top right corner.
    • The pull tab on this connector may be labeled DPAD.
  11. Steam Deck OLED Left Bumper Removal, Disconnect the touchpad board: step 11, image 1 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the touchpad board: step 11, image 2 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the touchpad board: step 11, image 3 of 3
    • Flip up the small locking flap on the touchpad board cable ZIF connector, located just below the previous one.
    • The pull tabs on the remaining ZIF connectors in this procedure may be labeled DB.
    • Lift the connector until its arms are free and slide it straight out to disconnect it.
  12. Steam Deck OLED Left Bumper Removal, Disconnect the left haptics: step 12, image 1 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the left haptics: step 12, image 2 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the left haptics: step 12, image 3 of 3
    • If you aren't replacing your button board, you can leave this cable connected and lay the board over the right side of the frame after you've removed the screws.
    • Be careful when disconnecting the haptics, as the cables and connector are very delicate. Pry only on the base of the white connector and not on the cables or socket.
    • Insert the point of your spudger under the neck of the haptics cable connector.
    • Gently pry up to disconnect it.
  13. Steam Deck OLED Left Bumper Removal, Disconnect the left touchpad: step 13, image 1 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the left touchpad: step 13, image 2 of 3 Steam Deck OLED Left Bumper Removal, Disconnect the left touchpad: step 13, image 3 of 3
    • Flip up the small locking flap on the touchpad board cable ZIF connector, located just below the haptics connector.
  14. Steam Deck OLED Left Bumper Removal, Remove the left button board screws: step 14, image 1 of 1
    • Use your T6 Torx driver to remove the four screws securing the left button board:
    • Two 5.9 mm‑long screws
    • One 3.8 mm‑long screw
    • One 4.9 mm‑long screw
  15. Steam Deck OLED Left Bumper Removal, Remove the left button board: step 15, image 1 of 3 Steam Deck OLED Left Bumper Removal, Remove the left button board: step 15, image 2 of 3 Steam Deck OLED Left Bumper Removal, Remove the left button board: step 15, image 3 of 3
    • Insert the point of your spudger between the bottom right corner of the button board and the frame.
    • Pry up until you can grab the button board with your fingers.
    • Remove the button board.
    • During reassembly, make sure none of the five cables become trapped underneath the button board as you lay it into place.
  16. Steam Deck OLED Left Bumper Removal, Remove the left thumbstick screws: step 16, image 1 of 2 Steam Deck OLED Left Bumper Removal, Remove the left thumbstick screws: step 16, image 2 of 2
    • Use your T6 Torx driver to remove the three 5.9 mm‑long screws securing the right thumbstick.
    • During reassembly, hold the Steam Deck OLED off your work surface so it doesn't rest on your thumbstick as you tighten the screws.
  17. Steam Deck OLED Left Bumper Removal, Remove the left thumbstick: step 17, image 1 of 3 Steam Deck OLED Left Bumper Removal, Remove the left thumbstick: step 17, image 2 of 3 Steam Deck OLED Left Bumper Removal, Remove the left thumbstick: step 17, image 3 of 3
    • Grip the edges of the thumbstick board and rotate it counterclockwise to clear the trigger.
    • Remove the thumbstick.
  18. Steam Deck OLED Left Bumper Removal, Remove the left trigger: step 18, image 1 of 3 Steam Deck OLED Left Bumper Removal, Remove the left trigger: step 18, image 2 of 3 Steam Deck OLED Left Bumper Removal, Remove the left trigger: step 18, image 3 of 3
    • The left trigger is on your right-hand side when working on the Steam Deck OLED, as it's laying upside down.
    • The trigger clips into place on two pegs on the frame, which double as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's left clip.
    • Use your fingers to push the trigger toward the left as you wedge the spudger between the clip and the peg.
    • Use your spudger to pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the right peg first. Once in place, push down on the trigger to latch the left peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
  19. Steam Deck OLED Left Bumper Removal, Remove the left bumper assembly screws: step 19, image 1 of 1
    • Use your T6 Torx driver to remove the three 5.9 mm‑long screws securing the left bumper assembly.
  20. Steam Deck OLED Left Bumper Removal, Remove the left bumper assembly: step 20, image 1 of 3 Steam Deck OLED Left Bumper Removal, Remove the left bumper assembly: step 20, image 2 of 3 Steam Deck OLED Left Bumper Removal, Remove the left bumper assembly: step 20, image 3 of 3
    • Grip the left arm of the bumper assembly and lift it off its alignment pegs.
    • Slide the assembly to the left to clear the tab on the right edge of the frame.
    • Remove the assembly.
    • The D-pad and view buttons membrane might stay stuck to the underside of the bumper bracket. If so, remove it.
    • During reassembly, line up the bumper bracket with the alignment posts in the frame as you set it into place.
Clay Eickemeyer
86,340 Reputation
455 Guides authored
Guide Team Member of Guide Team
Staff
9 Members
13,420 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 51
