Sony Xperia Z5 Compact Motherboard Replacement
  1. Sony Xperia Z5 Compact Motherboard Replacement, Charging port flex: step 1, image 1 of 2 Sony Xperia Z5 Compact Motherboard Replacement, Charging port flex: step 1, image 2 of 2
    • Power off and remove SIM card tray.
  2. Sony Xperia Z5 Compact Motherboard Replacement: step 2, image 1 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 2, image 2 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 2, image 3 of 3
    • Heat up the back cover to soften the adhesive.
    • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
  3. Sony Xperia Z5 Compact Motherboard Replacement: step 3, image 1 of 2 Sony Xperia Z5 Compact Motherboard Replacement: step 3, image 2 of 2
    • Remove all 10 Phillips screws.
    • Disconnect NFC clip and flashlight clip.
  4. Sony Xperia Z5 Compact Motherboard Replacement: step 4, image 1 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 4, image 2 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 4, image 3 of 3
    • Remove the plastic bracket.
    • Pry up and remove back frame.
  5. Sony Xperia Z5 Compact Motherboard Replacement: step 5, image 1 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 5, image 2 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 5, image 3 of 3
    • Remove front camera.
  6. Sony Xperia Z5 Compact Motherboard Replacement: step 6, image 1 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 6, image 2 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 6, image 3 of 3
    • Remove rear camera.
  7. Sony Xperia Z5 Compact Motherboard Replacement: step 7, image 1 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 7, image 2 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 7, image 3 of 3
    • Remove loudspeaker.
  8. Sony Xperia Z5 Compact Motherboard Replacement: step 8, image 1 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 8, image 2 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 8, image 3 of 3
    • Release charging port connector.
    • Remove plastic protective bar.
    • Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
  9. Sony Xperia Z5 Compact Motherboard Replacement: step 9, image 1 of 1
    • Remove charging port flex.
  10. Sony Xperia Z5 Compact Motherboard Replacement, Motherboard: step 10, image 1 of 2 Sony Xperia Z5 Compact Motherboard Replacement, Motherboard: step 10, image 2 of 2
    • Remove the motherboard/battery assembly.
    • Using a spudger, release the battery connector from the motherboard.
  11. Sony Xperia Z5 Compact Motherboard Replacement: step 11, image 1 of 2 Sony Xperia Z5 Compact Motherboard Replacement: step 11, image 2 of 2
    • Slowly pull out the two battery tapes located on the right side of the battery.
    • Remove the battery from the motherboard.
  12. Sony Xperia Z5 Compact Motherboard Replacement: step 12, image 1 of 2 Sony Xperia Z5 Compact Motherboard Replacement: step 12, image 2 of 2
    • Place two pieces of binding tape on the center of the motherboard.
    • Reattach the battery to the motherboard.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 1,122
