Introduction
This guides will show you how to replace the battery in your Sony Xperia Z5.
Heat the back cover to soften the adhesive.
Place the suction cup and insert metal opening tool to open a gap from top side.
Insert the guitar picks and slide it to cut the adhesive underneath.
Remove back cover.
Does the adhesive in this step need to be replaced? Don't really want to lose the water proofing…
Usually the adhesive is slightly damaged during the opening procedure which might void the water resistance of the phone. So to re-seal the back cover it’s best to use fresh adhesive. If you don’t find a pre-cut adhesive tailored to the Z5 you can go with double-sided adhesive tape or an adhesive glue. If you find the remaining adhesive in good condition and trust it to do its job, the re-use it by heating it up a little bit and applying pressure to the re-attached back cover for a few hours.
Release battery connector and pull off the adhesive tape underneath.
Pry up battery.
Can you tell me the wire connection colour code of battery? because i brought the ones but its not working.
25 other people completed this guide.
7 Comments
worked a treat - simple straightforward - thanks!!
umm how do you put the cover back on?
Just push and then consolidate with heat, I used hair dryer.
can reuse the same cover, or need a new unit ?
