Introduction
How to disassemble the phone and replace the Loudspeaker.
Video Overview
Switch off the phone.
If you can't switch it off, you can use the OFF button near to the SIM card Tray.
Warm the Back Cover. You can use a hairdryer.
Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
Disconnect the Battery Flex Cable and remove the two Philips screws.
Li-Polymer Battery, 3.8V, 3200mAh
Part number: LIS1543ERPC
Part of the Volume/PowerON/Mic flex cable is affixed onto the Loudspeaker/Vibro motor module.
Under the Flex cable is the Loudspeaker.
You can change only the Loudspeaker or or the Loudspeaker & Holder module.
Loudspeaker & Holder module Part No: 1282-2013
