Introduction
This guide will replace the rear camera in the Sony Xperia Z1 Compact.
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
The replacement batteries probably come without the new NFC sticker, so you’ll have to transfer it from the original one to the replacement. This can be easily done with an iPlastix and a good amount of isopropyl alcohol. Do this carefully.
Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
