Sony WH-1000XM5 Motherboard Replacement
  1. Sony WH-1000XM5 Motherboard Replacement, Earpads: step 1, image 1 of 3 Sony WH-1000XM5 Motherboard Replacement, Earpads: step 1, image 2 of 3 Sony WH-1000XM5 Motherboard Replacement, Earpads: step 1, image 3 of 3
    Tool used on this step:
    iFixit Opening Tool
    $1.99
    Buy
    • Place the edge of an iFixit opening tool under the earpad cushion.
    • Slide it alongside the edge of the cushion until it detaches from the rest of the headphones.
  2. Sony WH-1000XM5 Motherboard Replacement, Motherboard: step 2, image 1 of 2 Sony WH-1000XM5 Motherboard Replacement, Motherboard: step 2, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the eight 2.4 mm screws along the outer inside edge of the left earcup.
    • The shell of the earcup will be loose.
    • Flip over the headphones and remove the shell of the earcup.
  3. Sony WH-1000XM5 Motherboard Replacement: step 3, image 1 of 3 Sony WH-1000XM5 Motherboard Replacement: step 3, image 2 of 3 Sony WH-1000XM5 Motherboard Replacement: step 3, image 3 of 3
    • Using your index finger and thumb, gently pull out the five ribbons attached to the motherboard.
    • Use a Phillips #000 screwdriver to remove the three 1.4 mm screws from the motherboard.
    • At this point there should only be two wires attached to the motherboard.
  4. Sony WH-1000XM5 Motherboard Replacement: step 4, image 1 of 2 Sony WH-1000XM5 Motherboard Replacement: step 4, image 2 of 2
    • Caution: Please wear safety glasses and take caution when handling a hot soldering iron. Without the proper safety precautions, soldering can cause burns, fires, and lingering health effects.
    • Using the souldering iron, carefully desolder the two wires that still remain on the motherboard.
    • Remove the motherboard.
Grace Spellman
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 69
Past 30 Days: 330
All Time: 3,010
