Introduction
This guide will walk you through tearing down the Sony WH-1000 XM5 headphones in order to access the daughter board containing the 3.5mm Jack, Power Button and Noise Cancelling button. Accessing this board will allow you to replace the entire board, replace individual components on it, or safely remove any plug debris that may be lodged within the 3.5mm jack.
Tool used on this step:iFixit Opening Tool$1.99
Place the edge of an iFixit opening tool under the earpad cushion.
Slide it alongside the edge of the cushion until it detaches from the rest of the headphones.
Orient the Left earcup so that the cushion is pointed up, towards you.
Insert a plastic pry tool, spudger, or similar implement behind the ear cushion. Gently pry the first clip free from the earcup.
Make your way around the perimeter of the earcup, releasing the rest of the plastic clips.
Tool used on this step:Phillips #000 Screwdriver$5.49
Using a Phillips #000 screwdriver, remove all 4 of these screws.
Removing the piece of foam in the middle of the earcup will reveal the main driver, as well as 4 more screws.
Using a Phillips #000 screwdriver, remove the last four screws within the interior of the earcup.
With all 8 screws removed, the shell of the earcup will be loose.
Carefully remove the shell of the earcup. There are no adhesives or screws left holding the assembly together, so no force should be necessary.
With the shell removed, you can now access the majority of the components housed within the left earcup.
Locate the small screw located between the two ribbon cables. It is marked "L4" and identifiable by the arrow pointing directly at it. Using a Phillips #000 screwdriver, remove this screw.
Carefully disconnect both ribbon cables from the top-most circuit board.
With the "L4" screw removed and the ribbon cables disconnected, you can safely pull up the small plastic frame with the two white gaskets.
Using a Phillips #000 screwdriver, remove the 2 screws holding the daughter board into the earcup.
With the screws removed from the board, you can now pry the daughter board from the earcup.
Using a plastic pry tool, spudger, or tweezers, carefully pry the board up and out of the housing.
With the board removed, you can now safely replace any of the components on it, or even the entire assembly.
