Sony Vaio VPCEB11FM RAM Replacement
  1. Sony Vaio VPCEB11FM RAM Replacement, Battery: step 1, image 1 of 1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM RAM Replacement: step 2, image 1 of 1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM RAM Replacement: step 3, image 1 of 1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM RAM Replacement, RAM: step 4, image 1 of 2 Sony Vaio VPCEB11FM RAM Replacement, RAM: step 4, image 2 of 2
    • Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
    • Once the cover has been loosened, pry the cover with your finger for it to come off.
  5. Sony Vaio VPCEB11FM RAM Replacement: step 5, image 1 of 3 Sony Vaio VPCEB11FM RAM Replacement: step 5, image 2 of 3 Sony Vaio VPCEB11FM RAM Replacement: step 5, image 3 of 3
    • Use your fingers to gently pull the white plastic strip outward on both sides.
    • Once you pull the strip, the strip of RAM will loosen up. Once loose the strip of RAM should lift out.
    • Once done with the top strip of RAM continue for all continuous strips.
Maxine Filcher
1,102 Reputation
8 Guides authored
UW Tacoma, Team 1-5, Rose Winter 2017 Member of UW Tacoma, Team 1-5, Rose Winter 2017
UWT-ROSE-W17S1G5
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 1,610
