Sony Vaio VPCEB11FM Keyboard Replacement
  1. Sony Vaio VPCEB11FM Keyboard Replacement, Battery: step 1, image 1 of 1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Keyboard Replacement: step 2, image 1 of 1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Keyboard Replacement: step 3, image 1 of 1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Keyboard Replacement, DVD Drive: step 4, image 1 of 2 Sony Vaio VPCEB11FM Keyboard Replacement, DVD Drive: step 4, image 2 of 2
    • Remove the 7mm screws with the Phillips #1 Screwdriver.
  5. Sony Vaio VPCEB11FM Keyboard Replacement: step 5, image 1 of 1
    • Grasp the DVD drive's face plate with your fingers and pull out.
  6. Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: step 6, image 1 of 3 Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: step 6, image 2 of 3 Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: step 6, image 3 of 3
    • Within the DVD drive compartment, press on the hole to push the keyboard out of its placement.
    • The keyboard may need to be loosened on its edges with a plastic spudger.
  7. Sony Vaio VPCEB11FM Keyboard Replacement: step 7, image 1 of 3 Sony Vaio VPCEB11FM Keyboard Replacement: step 7, image 2 of 3 Sony Vaio VPCEB11FM Keyboard Replacement: step 7, image 3 of 3
    • Carefully pull the keyboard back to expose ribbon connector.
    • Using a spudger, or your finger tips, carefully slide the the ribbon keeper open.
Maxine Filcher
1,135 Reputation
8 Guides authored
UW Tacoma, Team 1-5, Rose Winter 2017 Member of UW Tacoma, Team 1-5, Rose Winter 2017
UWT-ROSE-W17S1G5
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 1,926
