Sony Vaio VGN-TXN25N Display Screen Replacement
  1. Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: step 1, image 1 of 2 Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: step 1, image 2 of 2
    • Place the computer on a flat surface with the top facing up.
    • Open the screen.
  2. Sony Vaio VGN-TXN25N Display Screen Replacement: step 2, image 1 of 3 Sony Vaio VGN-TXN25N Display Screen Replacement: step 2, image 2 of 3 Sony Vaio VGN-TXN25N Display Screen Replacement: step 2, image 3 of 3
    • Locate the rubber screw caps at the two bottom corners of the screen.
    • Use your finger to remove the rubber screw caps.
  3. Sony Vaio VGN-TXN25N Display Screen Replacement: step 3, image 1 of 2 Sony Vaio VGN-TXN25N Display Screen Replacement: step 3, image 2 of 2
    • Locate the two screws, one on each bottom corner.
    • Unscrew the screws with a Phillips head size #0 screwdriver.
    • Keep track of the screws. They are small and easy to misplace.
  4. Sony Vaio VGN-TXN25N Display Screen Replacement: step 4, image 1 of 3 Sony Vaio VGN-TXN25N Display Screen Replacement: step 4, image 2 of 3 Sony Vaio VGN-TXN25N Display Screen Replacement: step 4, image 3 of 3
    • Use a plastic opening tool to gently lift the plastic casing that borders the screen.
    • Pop off the casing by working the tool around the outside of it.
    • Wiggling the tool may be required. The casing could be fitted snugly.
  5. Sony Vaio VGN-TXN25N Display Screen Replacement: step 5, image 1 of 3 Sony Vaio VGN-TXN25N Display Screen Replacement: step 5, image 2 of 3 Sony Vaio VGN-TXN25N Display Screen Replacement: step 5, image 3 of 3
    • Carefully flip down the screen so it rests on the keyboard.
    • Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
  6. Sony Vaio VGN-TXN25N Display Screen Replacement: step 6, image 1 of 1
    • Remove the screen.
Andrew Ricker
71 Reputation
1 Guide authored
Cal Poly, Team 5-3, Forte Spring 2012 Member of Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 3,587
